dam ratteling in exhahst
dr_46
Post by dr_46 »
there is a very annoying rattel in my exhaust as i excelerat through the rev range its driving me mad....my exhaust is spring clipped and so is the can i put heat shrink on the springs thinking that, that was the problem but its not i cant figure it out....please help
banoffee
Re: dam ratteling in exhahst
Post by banoffee »
all bolts tight? if you take the can off and shake it is it there?
failing that a dyno run would help. if you are anywhere near Essex on Saturday there is a dyno day @ Gibsons for a tenner a run. am sure you could then see what's rattling.
dr_46
Post by dr_46 »
i am in australia i know its not the can it might be the part that it slips on or the y looking part that connects 2 pipes into 1 has anyone else had this problem?
Cammo
Post by Cammo »
Are you sure it's a rattle and not just the exhaust resonating?
A yamamoto systems I had sounded very raspy/rattly, I always thought it was the exhaust springs causing it but it turned out to just be a resonant effect of the system.
I couldn't change it no matter what I did. If you have a spare muffler fit it up and see if it makes a difference, if it does it's just the system making the noise.
dr_46
Post by dr_46 »
sounds like it could be the problem...i am getting the maggot from tyga soon so ill find out thanks
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
Likewise with the resonance. I silenced every spring and still had the rasp after rebuildng the muffler. The baffles on a lot of import systems are buggered, so that could be it too. However there is a difference between a rattle and a rasp! As Datarock says, try your new maggot and if it still doesn't cure it, it's probably just the exhaust. Personally, I'm a fan of a raspy exhaust 8-)
'Take it to the Back'
Cammo
Post by Cammo »
dr_46 wrote:...i am getting the maggot from tyga soon so ill find out thanks
That will solve your problem - you won't hear anything over that muffler!
dr_46
Post by dr_46 »
well its been happening since i purchased the bike about 8 months ago so its been the main drive for the maggot...the rasp annoys me its a tyga fiberglass can it was a full can and was raspy after my accident i had to chop it in half and re attach it and its still raspy...my mate has the stainless tyga can and it sounds so much better without tht rasp..
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
mine does the same , been driving me nuts, i thought it was the springs rattling but i even took them off and still does it , ive sealed all joins with fire gum , still does it , must just be the resonance but is more of a tinny rattle than a rasp :(
Deviants AM/PM build
viewtopic.php?f=62&t=27307
alexwitham
Bike owned: 675R, GSXR6, NC30
Post by alexwitham »
Perhaps one of the rivets hasn't 'taken' properly, meaning its still loose.
