r6 rear shock update.
White2505
if you fitted the R6 shock to your bike for the road and stuck with the original spring then you may want to make use of the following link.
I ran the original spring for about a year and have just changed to a softer one. My bike has been transformed from having a skittish, rock hard, confidence sapping rear end to a thing of loveliness. The original r6 spring is just way to hard for the potholed, rippled, mangled mess that passes for roads round my way. It probably works really well on a track bike but my road bike became hard work and almost unpleasant to ride.
the original fzr spring rate is I think 325lb's
the r6 one is over 500lb's
I've just fitted a 375lb 7 inch spring from demon tweeks, took me about an hour all in.
link is here if you need it
http://www.demon-tweeks.co.uk/products/ ... =FLK4S0150" onclick="window.open(this.href);return false;
Re: r6 rear shock update.
what spring compressor did you use ?
White2505
fleabay specials for £30
these are the same
http://cgi.ebay.co.uk/4764-Motorcycle-C ... 3caa72b7fd" onclick="window.open(this.href);return false;
I bought from a guy called Kwackers who was a few quid cheaper.
They worked perfectly.
these are the same
White2505
here's the guy I bought off.
arrived within 48hrs.
http://cgi.ebay.co.uk/Motorcycle-Coil-S ... 2c535ddffa" onclick="window.open(this.href);return false;
plodder
That's brilliant that.
I took my R6 shock off because it was too hard and ended up with a nitron unit off a FZR1000 with I think a 425lb spring, which was much better.
I think I may be making that mod shortly.
White2505
I can thoroughly recommend it.
I've been thoroughly impressed with the 375lb rear spring over the last two days. It has reinstated my lost confidence as a result of the r6 spring on the road.
If it helps I weigh a little over 11 stone so if you are much more or less than that you may want to factor that in to your spring choice.
plodder
I'm a bit porky at 13 1/2 stone, which is probably why the nitron works well.
I'm just about to build up a 3TJ trackbike, so was thinking about using the R6 shock on that as it's a track only bike.
How does the standard R6 spring work on track (especially Oulton as it's my local)?
- Motorcycle Solutions
plod it works fine on the ones i fitted
fzrtim
- Bike owned: FZR400 FZRhybrid FZR600 RSV1k
I agree, r6 spring is spot on on track fully backed off.
Really a spring should be in the middle of the spring's loading, which is why a spring change is good.fzrtim wrote:I agree, r6 spring is spot on on track fully backed off.
