coolant / oil
Vfr400nc30
coolant / oil
Post by Vfr400nc30 »
this is gonna souns really thick and really stupid but do i put in the colant container and also when i check my oil levels do i screw the dipstick in or just dip it in? thanks for the help
Delboy
Re: coolant / oil
Post by Delboy »
To check the oil, keep bike up right, unscew dip stick, wipe clean then put back in without screwing it in, remove, check level.
Do this from cold or if you have run the motor leave for 5 mins for the oil to settle back down.
Vfr400nc30
Re: coolant / oil
thanks man nice one any idea on the coolant is it just water or do i buy something to put in there
Delboy
Re: coolant / oil
Post by Delboy »
For the coolant, if it's just a small top up you can use either water or anti-freeze.. I personally would use anti-freeze.
If you are unsure of the service history might be best to drain/refill with a 50/50 mix.
Vfr400nc30
Re: coolant / oil
ok so if it is for some reason compleatly dried out i should use the 50/50 mix or something else and thanks for the help by the way ;)
Deviant400
Bike owned: NC30, Kona Cowan
Re: coolant / oil
Post by Deviant400 »
i used "rock oil's" antifreeze its premixed and has no silicates so is better for the pump
http://www.demon-tweeks.co.uk/products/ ... de=ROCKOOL" onclick="window.open(this.href);return false;
this stuff i think it was
Deviants AM/PM build
viewtopic.php?f=62&t=27307
Vfr400nc30
Re: coolant / oil
thanks for the help guys
cbr400rrn
Bike owned: NC29 CBR600F
Re: coolant / oil
Post by cbr400rrn »
silkolene pro-cool is a ready mix coolant as well
Re: coolant / oil
Any silicate free anti-freeze thats suitable for motorcycle use should be fine. use it 50/50 with distilled water.
The silicate free stuff has no sand in it, which is fine in a car but can damage the waterpump.
The distilled water helps to cut down on scale etc in the system
