954 footrest set on 29 ?
zul_cbr
Bike owned: 1990 CBR400RR-L NC29
Post by zul_cbr »
I heard from a friend of mine that 954 footrest set is a straight swap with 29. Anyone could clarify this ? Thanks.
If yes, so that we can use 954 racing footrest set ?
Zul
racesupplies
Re: 954 footrest set on 29 ?
Post by racesupplies »
Hello Zul,there is a small chance the holes on the frame might be the same distance apart,other than that I would say no they wont work in any way.
cajun
Bike owned: MC22, NC29,NC35, 2 FZR400's
Post by cajun »
I actually heard the R6's will fit.
racesupplies
Nope,still not a chance,stacked gearbox and gearlever other way up.
PARUS
Post by PARUS »
As I remember gary_palaboy use something from cbr, but not sure about model. Check wit him
racesupplies
I can check all the centres etc if you know roughly which one.Cant see how it would work with a stacked box,most have the gearlever on the engine.Hole centres for the master cylinder would most likeley be another problem.
zul_cbr
Post by zul_cbr »
racesupplies wrote:Hello Zul,there is a small chance the holes on the frame might be the same distance apart,other than that I would say no they wont work in any way.
if they share the same distance, why it can't be use to 29 ? as for the rear m/c, i think custom bracket will do.
racesupplies
Wouldnt it be easier to buy a set that fits?
paasker
Bike owned: Aprilia RS125 Tuono, NC29 race
Post by paasker »
sc28 fireblades hangers should fit
Kind regards
Martin
racesupplies
Yes they will Martin,just tried the patterns over the 29s,they will be about 35mm back 25mm up.Thats fixed Harris copies.
