Service limit for front brake disk
I've got some 3TJ discs that are a bit worn but can't find a service limit anywhere. At what thickness should they be scrapped?
Are these disks the same as FZR600 disks?
Re: Service limit for front brake disk
The min for 4jh is 3.4mm,and i think they are the same as 400 one's but not sure.
Yes - lots of the Yamaha's use 298mm disks
I presume the offset is the same for all of the 298mm disks then?
- Motorcycle Solutions
Plodder
Standard front Disc 4mm
prolites i beleive 4.5mm
this is for all fzr400's
- Bike owned: 1990 fzr6 3he with a 4jh engin
Motorcycle Solutions wrote:Plodder
How about fzr6's ?
FZR 600 and/or (early) Fazer ??? They're essentially the same disk.
Things changed with the later wheels, the hole in the middle is bigger ... a good example would be the R6
