Renthal grips
bourney
Renthal grips
Post by bourney »
Will these fit my cbr400 NC23?
http://cgi.ebay.co.uk/RENTHAL-ROAD-RACE ... 3ca996cdf2" onclick="window.open(this.href);return false;
Also (yes i admit, i know nothing about grips etc) whats the difference between the 3 compounds??
I'm guessing it's just how soft the rubber on the grip is? right?
So a softer rubber will grip to your glove better???
If so then why would they sell a firmer rubber that dosn't grip quite as well as the softer one??
justmartyn
Bike owned: Only 2 left.....
Re: Renthal grips
Post by justmartyn »
Cant be sure those will fit, Renthal grips come in different lengths and unless I'm missing something they arent stating which those are. The 400 throttle tube is a wee bit shorter than that of larger capacity bikes so the grip will overhang and you wont be able to lockwire it. It way also foul on your bar ends.
The 3 compounds relate to the "feel" of the grip, and not necessarily how much it will grip to your glove. The softer the rubber however, the sooner it will need replaced. I have mediums on my bikes and swear by them.
Hope that helps.
bourney
Re: Renthal grips
Post by bourney »
Ahhh, so what size did you put on your bike mate?
any links??
cheers :D
bourney
Re: Renthal grips
Post by bourney »
After a very quick scan through ebay (got to go out in a sec) i found some 125mm grips and 120mm grips.
Does anybody know the correct size (if either :S) for the cbr400 nc23?
racesupplies
Re: Renthal grips
Post by racesupplies »
Quick tip,I use them on my vintage trials bike.If you get WD40 on them they turn to a sticky mess.Carefull if youre drying out damp switchgear.
bourney
Re: Renthal grips
Post by bourney »
racesupplies wrote:Quick tip,I use them on my vintage trials bike.If you get WD40 on them they turn to a sticky mess.Carefull if youre drying out damp switchgear.
Thanks for that, i have being spraying the switch gear on my other bike every time i've washed it latley to avoid ice building behind the buttons (jammed my starter button on last time i washed it in the cold and didn't spray with WD-40).
You've probably saved me a pair of grips :D:D cheers.
What do you spray your switch gears with then? silicone?
racesupplies
Re: Renthal grips
I dont really use it,I havent got a road bike.All my bikes have only got kill switches.
