Page 1 of 2
How to make rear hub ligther ?
Posted: Sun Jan 10, 2010 10:28 pm
by PARUS
Just only an idea - is it possible to make rear hub lighter and are there big benefit for the rear wheel ?
Re: How to make rear hub ligther ?
Posted: Mon Jan 11, 2010 11:17 am
by greggo
There are a few ways you could make it lighter. But little point. The money would be better spent on a set of wheels off an RS250.
Biggest gains are to be had by removing weight from the point furthest from the centre of the wheel. ie the rim.
Posted: Mon Jan 11, 2010 12:32 pm
by dannc29
going wider would be the best benifit
Posted: Tue Jan 12, 2010 12:03 am
by racesupplies
Taking unsprung weight from the end of the swingarm cant be a bad thing,theres lots to be had by losing the stock caliper and bracket as well. I made a new underslung one that weighs 600g less,and the wheel goes straight in without the comedy juggling act.
Posted: Tue Jan 12, 2010 3:37 pm
by Wozza
racesupplies wrote:Taking unsprung weight from the end of the swingarm cant be a bad thing,theres lots to be had by losing the stock caliper and bracket as well. I made a new underslung one that weighs 600g less,and the wheel goes straight in without the comedy juggling act.
What caliper do you use?
Posted: Tue Jan 12, 2010 3:47 pm
by racesupplies
Its a 2 bolt Brembo,fitted to lots of Ducati etc. I have lost track of how much weight removed this winter,but I think the complete swingarm is nearly a kilo less than when I started.
Posted: Tue Jan 12, 2010 4:12 pm
by Wozza
Could you easily make a bracket for the NC23?
Posted: Tue Jan 12, 2010 4:21 pm
by racesupplies
It took over a day to make the one for my bike,but the first ones take longest.I did wonder about selling them,but havent had enough time to sort out how much a small batch would come to.Is the 23 much different? I made mine from 25mm billet,it could be profiled with a water jet,there is a lot of material to come off.About 50 percent went into the bin.
Posted: Tue Jan 12, 2010 10:05 pm
by Wozza
NC23 has different bracket and caliper, similar setup though.
Posted: Tue Jan 12, 2010 10:17 pm
by racesupplies
What about the hub?
