RVF wrist pin size
Variablevalves suck
RVF wrist pin size
Post by Variablevalves suck »
Could any of you in the know guys help me out and tell me the lenght and diameter of the RVF piston wrist pin.
Many thanks Chris.
Variablevalves suck
Re: RVF wrist pin size
Come on lads help a man out. :pray:
Don't know... :cry:
But this was discussed on here as it was found that the wrist pins for the VFR was not the same.
There is a thread on here somewhere.....
I'll go have a look..... :geek:
http://www.400greybike.info/newforum/vi ... =wrist+pin" onclick="window.open(this.href);return false;
OK - so not that one..hmm..
Pimp pistons though..lol
Variablevalves suck
Cheers for that, a very interesting read, but not actual measurements for the little end wrist pin. Im building up a gsxr motor and read that the RVF pin was about 27gramms so would sve me 5gramms to swop over, IF the sizes are good. Gsxr is 56mm standard bore so should be close oif the dia is the same. 8-)
racesupplies
Post by racesupplies »
The pin is 14mm diameter,39mm long.Same as NC29.
Variablevalves suck
Thanks very much for the info :worthy:
That will explane the lighter pin as the Gixer one is 16mm X 44.5mm.
Chris.
racesupplies
What are you doing with it when its running?
Variablevalves suck
Just a motor for my track bike, but being a bit strange i like suzuki's so keep chipping away at a couple of engines ive got. Always after a cheap mod so will try anything.
Chris.
racesupplies
Try a search on Isle of Man TT96 400 race Alan Bushell.
