Does this sound normal? (1991 NC29)
madmike
Bike owned: CBR400RR NC29
Post by madmike »
Well... Ive recently had my Carbs balanced at the local garage (about a month ago)...
Before it became minus figures in the temperature! To start the bike (even when it was relatively cold outside) I wouldn't need choke or throttle... just press on the button then when she has started a quick flick of the wrist to keep her going....
But now that it has gotten really cold it just WONT cold start :down:
Sometimes it may fire once but I have had to bump everytime... THEN when its running i have to give it some choke BUT when i pull the choke full it sounds as if its flooding :?
Someone told me this may not be normal? :?:
Davez29
Bike owned: NC29 forever
Re: Does this sound normal? (1991 NC29)
Post by Davez29 »
When its cold I find my bike is harder to start, generally I turn over with a little throttle and at the same time whip the choke out to around half way, it then fires and I then adjust the choke to suit, letting it idle, no throttle around 2.5 thou to 3 thou on the clock until I get a clean uptake, then away I go.. Hope that helps until someone else answers.
madmike
Post by madmike »
Durka Durka wrote: then adjust the choke to suit, letting it idle,
Does it usually stutter as if its flooding if you give it too much choke? :roll:
zul_cbr
Bike owned: 1990 CBR400RR-L NC29
Post by zul_cbr »
For my 1990 NC29, no. More choke, the more revs...
leopard_pagan
Bike owned: CBR400/600 Fighter
Post by leopard_pagan »
i guess we start our bikes differently.
1) key in ignition and on
2) pull choke out 1/4 -1/2 way
3) press start button straight after coke
4) give a small twist o wrist when it fires.
5) leave on choke for a min or so.
no probs
Mikiboy
Bike owned: RVF400 NC23 x 2 NC29 CBR4/600
Post by Mikiboy »
Very few start the same.
I have ione that never uses choke and the other 3/4 and no throttle
