ducati front ends..
Bill
ducati front ends..
Post by Bill »
So ive got the duc front end on my almost compleate nc30, and with the original clocks and lighs and (original style) farings ive found there is no room for my ignition, anywere, any ideas as im pritty stuck..? :lol:
Thank you, Bill
Sligeach
Re: ducati front ends..
Post by Sligeach »
email a member on here called riley or smev, both have duc front ends, they will help you out
abrmoto
Bike owned: RVFx5,SP1,MV F3,C90,Firestorm
Post by abrmoto »
Think Drunky Monkey has set of forks as well if you need a set.
Riley
Post by Riley »
Hi Bill,
My ignition barrel is located where the right hand (as sat on the bike) headlight should be as I run an endurance nose cone, Smev has a conventional fairing so no doubt he will be along soon to enlighten you, Jason machined a plate which sits under the top yoke and locates the ignition (his bike is now owned by badbannedbiker).
Smev
Bike owned: NC30 of course
Post by Smev »
I have relocated the ignition and used one where I can remove the key once it has been turned. the reason for this is that I have put the ignition in the fairing infill panel - approximately the same location as the choke on the NC30 but on the right hand side of the bike.
I then bought some carbon infills from a forum member and have relocated it again. this time to a bracket in the vent/cut out in the mid fairing panel.
Hope this helps.
Smev 8-)
Mister Donut Rep NC30
Bill
Post by Bill »
ah okay, i like the bracket machining idea, some pics of that might be cool i'll pm, and yea ive spoted the ignition in some pics of yours riley, but ive kept both lights and ther just isnt the room up front for it now :P ... smev i'll have another play with it when the snows buggerd off! some nice ideas at least cheers guys!
Bill,
