nc30 brake lever & master cylinder
muay_thai_dan
hey guys, i need a brake level and master cylinder for an nc30. a complete assembly.
im dondering if i should just get the stock original ones, or if there are some better / performance / better quality assemblies out there?
if you have these, or know of where i can get them please reply with a link! for stock and performance part.
thanks a lot guys!
thanks a lot guys!
Spike16
Re: nc30 brake lever & master cylinder
Iv got an r1 mastercylinder that will be for sale as soon as I get it off the bike and can sort a replacement, comes with res and lever... £35 posted
muay_thai_dan
thanks. r u taking it of your nc30 or off an r1?
could you show me some pics. also, im located in toronto canada.
Spike16
off my nc30, iv got cbr900 calipers which are bigger so need an even bigger master as their still a little too much lever travel for me (I like my lever far out and not much movement), the r1 one should be a decent improvement over the stock one if you using stock calipers tho
muay_thai_dan
sounds good.
how will this r1 setup make my lever feel? i too like it firm with not much travel.
if you have pics that would be great.
Don't want to piss on your parade here Spike..
@ Dan - I see you are looking for an m/c to match the cbr6/blade/Sp style calipers - this R1 jobby is not what you want.
You need a 5/8 size - approx 16mm - which is what I use (and Honda spec) for the calipers you have.
This is a larger bore adn so will be squidgy with awesome power til it crushes the fingers on the bars....
Sorry Spike..
Sorry Spike..
Spike16
yeh if you want cbr calipers then this isnt the master 4 u I dont think (wasnt for me anyway) if your keeping the stock calipers then this will do fine
carl44
hi sorry to jump in but could do with a bit of info , iv got an isr mastercylinder with stock calipers , wot would be the best calipers to fit to match the isr cheers carl44
muay_thai_dan
CMSMJ1, thanks for the input.
so what m/c should u get for the upgraded brakes ? im guessing an m /c of of the same bike i get the brakes of would make sens?
ex. if sp1 brakes - sp1 m/c ?
Yes, pretty much. I have the CBR600FX calipers and use a 1999 blade m/c - My brakes are wicked.muay_thai_dan wrote:CMSMJ1, thanks for the input.
@ carl - depends on your ISR bore size - if it ain't broke..don't fix it
