my 29 with 35 calipers
zul_cbr
Bike owned: 1990 CBR400RR-L NC29
Post by zul_cbr »
How was it guys ?
btw, I'm still using stock master cylinder. any side effect for that ?
Re: my 29 with 35 calipers
Cool - but seeing as you have them fitted...hows about the Sp1/Blade/CBR6rr style Nissins that are even better than them?
You'd want a new m/c from the same bike but they are the brakes I use on my '30 and they are hard as nails.
zul_cbr
Post by zul_cbr »
Thanks CMSMJ1, but the SP1/CB400 Vtec/Blade/600RR gold Nissin calipers are quite expensive here and it slightly lower than Brembo Goldline caliper. If I have the budget, for sure its Brembo :lol:
btw, m/c for '30 and '35 share the same internal diameter cylinder size (14mm). no wonder why they are hard as nails. but, '29 are just smaller than that which is 12.7mm.. I'm afraid that later it will be a problem (e.g jammed brakes) if i'm still using the stock '29 m/c with these '35 caliper.
Wozza
Post by Wozza »
Are they four-piston calipers?
Cammo
Post by Cammo »
zul_cbr wrote:Thanks CMSMJ1, but the SP1/CB400 Vtec/Blade/600RR gold Nissin calipers are quite expensive here and it slightly lower than Brembo Goldline caliper. If I have the budget, for sure its Brembo :lol:
They're cheap on US ebay. I got a set of good SP1 calipers for less than USD$100 to my door.
zul_cbr
Post by zul_cbr »
Wozza wrote:Are they four-piston calipers?
yes, upgraded version for '30 calipers.
Whats the diff beside the nice gold colors and design ?
tanuki
Post by tanuki »
a larger piston.
bourney
Post by bourney »
CMSMJ1 wrote:Cool - but seeing as you have them fitted...hows about the Sp1/Blade/CBR6rr style Nissins that are even better than them?
Are they all striaght fits?
What about for the cbr400 nc23? Can i use those calipers on that?
zul_cbr
Post by zul_cbr »
no, you have to do a custom bracket to fit those calipers.
guys, i have seen 29 fitted with RC30 calipers. is it a straight swap coz i dint see any customised bracket. or maybe its using RC30 forks as well ?
They'll be NC30 fork bottoms ;)
