help needed
vtiimport
help needed
i brought a nc30 as a little project, finaly got it running last week, seemed to be ok would start with no throttle. started it on saturday but as soon as i reved the bike it would die, the first thing i thought was that it was flooded but is there any thing else i should check
thanks rob
thanks rob
- hannakournikova
Re: help needed
did you clean carbs out? strip them, degunk and put back together...
1990nc30
Re: help needed
Check your tap as this was what had happened to mine when i bought it, i took the vacum out and it ran fine, but before it had exactly the same symptoms as your saying, i thought it was flooding too! I've tried putting a brand new vacum kit back in my tap but it still wouldn't run, started up with no throttle and it died when i revved it, so out came the vacum again!
I think this should be your problem mate take your tank off, whip the tap off, dismantle it and take out the diaphram, then see if she goes then.
vtiimport
Re: help needed
thanks for the replies, think i will give the fuel tap a go first as it shound easier, then if that don't work off with the carbs
Re: help needed
can you get it to start on the choke?
let it warm up a bit before revving it and see how it goes?
razor400
Re: help needed
thats what I was gonna sayCMSMJ1 wrote:can you get it to start on the choke?
vtiimport
Re: help needed
it will start sometimes but it wont run for long, till it cuts outCMSMJ1 wrote:can you get it to start on the choke?
1990nc30
Re: help needed
Have you tried what i said the other day, definately worth doing as i reckon this is your problem. If it starts with choke you only have to give it a few seconds before revving it and if it dies then, the fuel is not getting through.
vtiimport
Re: help needed
was working on the bike yesterday, you was spot on, works fine now thanks1990nc30 wrote:Have you tried what i said the other day, definately worth doing as i reckon this is your problem. If it starts with choke you only have to give it a few seconds before revving it and if it dies then, the fuel is not getting through.
