NC29 side stand question
zul_cbr
- Bike owned: 1990 CBR400RR-L NC29
hi all
my bike recently had a problem with the stand switch (seems like the intermittent connection). how to disable the switch but keep the indicator functioning ?
based on the wiring diagram, there is a 3 wires coming out from the stand switch.
GREEN - ground
YELLOW/BLACK - indicator
GREEN/WHITE - ignition control unit (cdi)
what happen if i cut the GREEN/WHITE wire ? btw, i'm no good in electrics.
thanks in advance.
GREEN - ground
thanks in advance.
PARUS
Re: NC29 side stand question
Just connect YELLOW/BLACK and GREEN/WHITE and your switch always will be switch on. But I think you can simple clear switch inside.
zul_cbr
thanks Parus
