NC35 Yoke fitting to an NC30
I am sure i have seen this one, is there a kit to fit NC35 yokes to an NC30 as
i have everything else, except i have fitted ZXR 400 yokes and am having countless
problems so it may be easier to see if i can fit NC35 yokes.
Any thoughts
Regards lee
Any thoughts
Regards lee
Re: NC35 Yoke fitting to an NC30
here are a couple of pics i think i sore which has this done?
http://i29.photobucket.com/albums/c291/ ... 8Small.jpg
http://i29.photobucket.com/albums/c291/ ... 1Small.jpg
you need to mod the yokes by fitting an NC30 stem to the NC35 yokes.
Not to sure i understand not to up on my yoke knowledges?
- hannakournikova
these any use to ya....
http://www.400greybike.cc/newforum/view ... 8742#p8742
The yokes are in 2 pieces. top and bottom
Bottom yoke has a stem that slots into the headstock and runs on the bearings and the top toke clamps to this with the headstock nut.
The NC30 adn 35 have different sized stems and so you cannot just swap them over.
You can have them pressed out of the yokes and a new stem, of the right size, pressed in. This is a ballache.
