Runs like a sack of hammers
johnnyyellowpants
- Bike owned: 1960 Matchless G9, Fazer 1000
Hi,
I have a nc 23 J which I have bought as a "project" track bike.
I have just got it back to-gether and here`s my problem.
It would only run on 3 pots, number 2 being the duff`un.
It had a good spark so I stripped the carb hoping to find it full of gunge!
In fact the carb was really clean inside but the pilot jet was blocked?
I cleared the jet and reassembled the carb, and off she went on 4 cylinders again.
But.......... I wont rev above about 6 k??
Now I don`t have an airfilter fitted at the moment (long story) do you think this is the problem?
Yes I know it not a good idea to run it without the filter
JK
JK
Re: Runs like a sack of hammers
lol - put a filter on it. it may just be too lean to rev above 6k
or, do you have a speedo connected?
It should rev above 6k without a filter, bikes run faster with a weaker miture.
Compression test it
Compression test it
johnnyyellowpants
My mate is bringing his compression tester round on Saturday.
Watch this space!
Watch this space!
If there the same as NC30/35's then as CMSMJ1 said if the speedo is not connected it wont rev above a certain rpm
johnnyyellowpants
The came to me in track formate, no speedo.
Is there a way of eliminting the speedo?
thanks
JK
thanks
JK
johnnyyellowpants
Did the compression test today, 3 @ 110 PSI and 1 @ 105.
Improvised an airfilter and let it warm up thoroughly, now runs fine.
For the replies
For the replies
