Forks 750VFR??
neurosyndrome
Forks 750VFR??
Post by neurosyndrome »
Hi everybody,
I'm wondering if the forks (I mean the tubes) of VFR750 92-93 are the same than our nc30's later type forks :idea:
Or maybe, it could be the same than VFR750 86-87?? 94-97??
I hope someone will be able to reply :pray:
Thanks all :grin:
fastdruid
Regular Member
Re: Forks 750VFR??
Post by fastdruid »
Don't think so, No definitely not[1], don't think so.
Druid
[1] 86-87 are 37mm, 88-89 are 41mm but far, far too long.
Re: Forks 750VFR??
fastdruid wrote:Don't think so, No definitely not[1], don't think so.
Druid
There about 60mm longer than the NC30 tubes If I remember rightly..
JZH
Bike owned: RSCBRRVFVFRST
Re: Forks 750VFR??
Post by JZH »
VFR750F fork tubes were 41mm OD (same as NC30) from 1990 to 1997, but much longer than NC30. CBR600F from the same era were also 41mm but generally even longer, but Firestorm VTR1000F forks are a little shorter than VFR750F. Probably not enough to not poke through the top triple clamp, though. Longer is usually easier to deal with than shorter!
Ciao,
JZH
London, UK/So.Cal., USA
http://www.vsource.org" onclick="window.open(this.href);return false;
JZH
www.vsource.org
Re: Forks 750VFR??
JZH wrote:VFR750F fork tubes were 41mm OD (same as NC30) from 1990 to 1997, but much longer than NC30. CBR600F from the same era were also 41mm but generally even longer, but Firestorm VTR1000F forks are a little shorter than VFR750F. Probably not enough to not poke through the top triple clamp, though. Longer is usually easier to deal with than shorter!
Ciao,
JZH
CBR600F forks might be very similar to the CBR400RR NC23 forks as my old man used to have an NC23 with 600 forks in it.
