Rearset sizes ..
castrol101
Rearset sizes ..
Does anybody know if rearsets from an NC30 will fit an NC24??
Or if the pegs are the same size/fitting??
Im looking at getting some new as mine are looking worn but I can't find any specific to NC24
Any help appreciated :)
Re: Rearset sizes ..
I doubt it, best bet might be to get someone to measure the distance between the mounting holes.
The pegs will most likely be interchangeable.
randallbass
mounting holes are 70mm on an 1992 nc30 :)
cheers Tim
cheers Tim
castrol101
Thanks Tim, I'll have a look at mine later.
castrol101
Do you mean 7mmmounting holes are 70mm
randallbass
pretty shore the holes are 9mm for an 8mm bolt, i meant 70mm hole centers :)
cheers Tim
cheers Tim
