front brake bleeding...
just woundering really if there is like a special spanner/ tool i need as my old man has question this, and now im not sure i thought to be honest whatever size ring spanner fits the nipple would do it? dont want to round it off useing the wrong thing
so i figured i better check with those in the know! as ive only done it once before along time ago,thoughts and tips apriciated (its a ducati front end so brembo calipers)
Cheers Bill
Cheers Bill
Re: front brake bleeding...
so i figured out what he was on about anyway :D cheers
A 8 mm spanners was fine on all the bikes i have done over the years (but then again none of them had brembo calipers, so someone else can check this for you). As for bleeding the brakes, its good to have 2 people, 1 at the lever and 1 at the caliper and make sure you never get air into the system, so keep topping the brake reservoir up until enough brake fluid has pass the system (so the new stuff displays the old stuff). This is so that you dont waste huge amounts of new brake fluid trying to get the air bubbles out of the system.
Hope that helps
Hope that helps
Get yourself a 5ml syringe from Superdrug/Boots and put a piece of rubber pipe onto the end and attach the other onto bleed nipple.
Open bleed nipple with 8mm spanner and drawn air out with syringe.
With syringe still full, of mostly air but some fluid, close nipple and then push syringe back down to bottom.
Keep doing that until your'r getting lots of fluid out. Then lose the syringe and stick the loose end of rubber pipe into some old fluid and bleed as per Haynes, ie pump lever with nipple closed, open it and watch bubbles come out into your old fluid.
Simples.
Simples.
How hard can it be?
Cheers for the rplys guys
i will be haveing a go at it sometime this weekend i will let you know how i get on
Bill,
Bill,
sorted it now! and man dose it stop... went for a little tester on it today about my street and apart from the reduced lock witch i kept forgeting about its spot on today was the first time in 6 months on the bike. now i cant wait to get it finished and MOTed ect...
Bill,
Bill,
