Please help
erniegogs
Please help
Post by erniegogs »
Hi, can anyone shed some light on this?
The bike was running ok, except it would not go over 100mph (normally does it easy) too much oil was put in the engine and when i gave it some tring to clear it. It choked and blew out a load of blue smoke. and then chuffed when it was ticking over.
I have replaced the rings, head gasket and ground the valves in. Fresh oil and filter but it is still doing the same, the block and head both looked ok and no oil water mix when I drained it.
I have been asked if the breather is blocked but the only one I can find on top of the head it blowing out ok.
I'm about to throw it in the river. please help if you can. It runs ok with out any knocks or bangs.
Ernie
greggo
Re: Please help
Post by greggo »
What do you mean by choke?
Too much oil was put in the crank case?
There are only a few places oil can get into the cylinder from, did you check the valve stem guides/seals?
erniegogs
OIL sorted....
Post by erniegogs »
Thanks for those who offered advice.
Cause = when it presurised, it filled the carbs with oil and mixed with the fuel.
cleanned the carbs and it it SMOKE FREE..
cheers :clap:
Cammo
Re: OIL sorted....
Post by Cammo »
erniegogs wrote: too much oil was put in the engine and when i gave it some tring to clear it. It choked and blew out a load of blue smoke. and then chuffed when it was ticking over.
erniegogs wrote: Cause = when it presurised, it filled the carbs with oil and mixed with the fuel.
No offense intended, but no sh!t, you filled it too full of oil and it had to end up somewhere, there is no way to clear it unless your rings or other engine parts are stuffed!! ;)
