Racing camshaft and QUEITENING GEARS REMOVING ?
PARUS
Guy,
Have couple of questions.
1. Where possible to get racing cams? I have read Kent Performance Cams Ltd http://www.kentcams.com/ made them before? What about now?
2. Why QUEITENING GEARS need to be remove? I understood that should be done to allow the cam timing to be spot on. But do not understand principals in details. And one more thing is not clear - if we remove secondary gear in this case we will have two neutral.
So, need explanation
GF Racing
Re: Racing camshaft and QUEITENING GEARS REMOVING ?
Sold two used good sets last week to this forum users @ £100 a pair - plus we keep unused Kent race cams in stock @ £340 a set outright purchase.
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
PARUS
Graeme, should I remove second gear in case I will fit Kent cams ?France & Li Asia Tdg wrote:Sold two used good sets last week to this forum users @ £100 a pair - plus we keep unused Kent race cams in stock @ £340 a set outright purchase.
PARUS
Graeme, do you have somewhere list of parts you have in stock. Excell file is fine or similar like this. As for the camshaft - are mandatory make head poring and removed second gear to fit this ?France & Li Asia Tdg wrote:Sold two used good sets last week to this forum users @ £100 a pair - plus we keep unused Kent race cams in stock @ £340 a set outright purchase.
Less friction if you remove the camshaft quietening gears. They are not related to the gearbox.PARUS wrote: 2. Why QUEITENING GEARS need to be remove? I understood that should be done to allow the cam timing to be spot on. But do not understand principals in details. And one more thing is not clear - if we remove secondary gear in this case we will have two neutral.
I have them removed on my nc30 racebike, it now produces a mental sound (similar but nicer than a Ducati dry clutch type noise).
Quietening gear is the thin gear next to the main gear:
PARUS
Thank you Stickshift. That's make thinks little bit clear. Looks like sound will be similar like on this video http://www.youtube.com/watch?v=eTfm_Tye3uw&hl=ukStickshift wrote:Less friction if you remove the camshaft quietening gears. They are not related to the gearbox.PARUS wrote: 2. Why QUEITENING GEARS need to be remove? I understood that should be done to allow the cam timing to be spot on. But do not understand principals in details. And one more thing is not clear - if we remove secondary gear in this case we will have two neutral.
PARUS
I found guide how it can be done on rc51 http://www.motophotos.com/rc51online/Mo ... index.html Similar should be for NC29...
revs27
i actually designed and made set of cam sprocket adaptors to fit the standard nc29 cams so u can adjust the timing. and also removes the quietening gears if your interested.
greggo
I started removing the quietening gear on my exhaust cam (already removed on my inlet by prev owner) only to find out it isn't that simple!
So i now have the gear removed but have the issue of drilling out the old locating pin to replace with a bolt.
Not a home job Parus, nothing like the link you have posted above.
Interested to know how you did the removing and replacing Revs27!
PARUS
Greggo,greggo wrote:I started removing the quietening gear on my exhaust cam (already removed on my inlet by prev owner) only to find out it isn't that simple!
Will be appreciate if you upload picture of this location pin.
