Donnys carb cleaning progress
Donny
Bike owned: GSXR 400
Post by Donny »
took carbs off bike other day as they need cleaning so i thought i do a tutorial on cleaning carbs for a gk73A.
tools needed
some carb cleaner
a small tool to get in small places
4MM alen key or 4mm socket alen with wrench.
the carb cleaner i used (got it from bullseye)
http://i656.photobucket.com/albums/uu28 ... leaner.jpg" onclick="window.open(this.href);return false;
the small tool i used to get in small places.
http://i656.photobucket.com/albums/uu28 ... cttool.jpg" onclick="window.open(this.href);return false;
step one remove the bottom of the covers (just like how ive done)
http://i656.photobucket.com/albums/uu28 ... /Carbs.jpg" onclick="window.open(this.href);return false;
grab hold of one of the bottom peice ( like this )
You see the mucky gunk (YUK)
http://i656.photobucket.com/albums/uu28 ... kygunk.jpg" onclick="window.open(this.href);return false;
remove the sealance as shown here
spray the carb cleaner stuff in the bottom peice
http://i656.photobucket.com/albums/uu28 ... ntered.jpg" onclick="window.open(this.href);return false;
use the little tool to scrape up and down while the cleaner is inside but dont empty the carb cleaner stuff..
then leave for about 20 minutes and then hot water and empty the carb cleaner while u are doing that use the little tool to do the top of the peice where the sealance goes as u be suprise how dirty it is
http://i656.photobucket.com/albums/uu28 ... eaning.jpg" onclick="window.open(this.href);return false;
use the carb cleaner on the rubber sealance too and then just wipe it with a old cloth and then put the sealance back on the peice
http://i656.photobucket.com/albums/uu28 ... edback.jpg" onclick="window.open(this.href);return false;
then put it back on the carb :)
Hope this helped :)
