gk76a Parts required, Supplier suggestions appreciated
Hey, my 76a needs a good overhaul so could really use suggestions on suppliers and prices for the following bits
- Carb o-ring set
- Head and Base gasket
- Valve Stem seals
- Carb o-ring set
- Valve Stem seals
- Variablevalves suck
Re: gk76a Parts required, Supplier suggestions appreciated
Hi mate,
I do the o'rings for £11 posted, regards the gaskets and seals its Suzuki for originals or an aftermarket set that comes with everything if available. bandit and gk73a stem seals will not fit as they use bigger dia valves. Try Robinsons and if they carnt help you can buy direct from japan via Riders of Yovil.
Robinsons Foundry 01227 454366 or if you have the part numbers you can put it straight into their website for prices: http://www.robinsonsfoundry.co.uk/shop/ ... index.html" onclick="window.open(this.href);return false;
Cheers for the help. Was going to try the foundry but was wondering whether anyone recommended somewhere else. V Valves PM me how you would like to send some money your way.
Hopefully the ickle gixxer will be back up to scratch shortly
Dont forget to check http://www.wemoto.co.uk...." onclick="window.open(this.href);return false;. Tho their stock selection aint complete for the bike, its worth a quick look, nice site to use.
Use wemoto quite a bit. Seem to have changed a shed load of fork seals on these things.
