nc30 brakes and front wheel upgrades.
crashercrisp55
hiya i tryin to sort out my nc30 to race next year and have been told that the sp1 calipers and master cylinder will fit straight onto my standard forks...is this correct???? also i was told that the cbr 400 3 spoke front wheel and discs will also fit straight in and with the sp1 calipers. has any one done this? also any other advice on weight saving and handling would be a great help.
cheers jamie
cheers jamie
pugparcels
Re: nc30 brakes and front wheel upgrades.
sp1 / fireblade calipers will fit straight on but you need to buy some brackets as the mounts are different. rick oliver is your man. not sure on the cbr 400 wheel though...
crashercrisp55
nice 1 thanx, the front wheel idea was purely for lowering weight as a set of dymags are a lil bit on the expensive side!! not that i think it would make a huge difference.
kevprojex
- Bike owned: ktm200exc gsxr400gk71b sv650
no need to change the calipers on the nc30, they are 4pots anyway ? , just fit some bendix road/race pads , i fitted them in my track bike and they transformed the brakes from the ebc pads that were fitted before , twice the bite and half as mutch leaver presure needed ,best mod i ever done and no more arm pump .
- mavisravis
- Bike owned: NC30 Race Bike
NC23 wheel goes straight in, and saves a bit of weight too.
et voila.. NC23 wheel, CBR600FX calipers (black ones) amd the mounting brackets from Rick Oliver.
Throw in a fireblade m/c and the brakes are rocking)
The Hamster
Im going to go completely OFF THE RAILS!!! on my Project NC30. LOL
After Seeing a member on Here can supply Ducati Front End fitting Kits, The plan for my project bike when I win the lottery, (LOL, Join the RAF more like and have £1500 spare each month...
) is to fit Ducati 999 Yoke Upgrade, but then they will be upgrades aswell, Lightened and Machined Jobies hopefully, Ohlins R&T Front Fork Kit, (REALLY NOT CHEAP!!!), Ducati Upgrade Carbon Fibre Front Wheel, And Brembo Street/Track Race replica Radial Callipers and Pads along with a Brembo master cylinder Unit if i can find one and a Really good Lightweight set of Discs..
(Can you tell Im going for the Lightweight Theme?? LOL)
That should Pimp it up a bit. LOL
