Which forks?
tanuki
Which forks?
Post by tanuki »
I believe that there are some later model 636 radial brake forks that fit the ZXR400 yokes?
Is this true?
Si
Re: Which forks?
Post by Si »
yeah the zx6r forks fit the zxr400l yokes
not sure of the prefix for the fork legs but I think its the c1h models
tanuki
Re: Which forks?
Post by tanuki »
and are they radial jobbies?
Si
Re: Which forks?
Post by Si »
Ballsout Racing
Re: Which forks?
Post by Ballsout Racing »
2003/2004 is what I used. 2005/6 will also work but the disks are bigger so don't mix years without checking wht works with what. They're 25mm longer than the 400 forks so will need that showing above the yokes.
http://www.zxrworld.co.uk/zxr400oc/down ... &mode=view
too fast
Re: Which forks?
Post by too fast »
are the spring rates about right for the 400?
Ballsout Racing
Re: Which forks?
They're 8.5kg instead of 8. So perfect for track. Maybe a bit stiff for the road and if you're a lightwieght ;)
