need help with RVF400 carb parts
- royster81
http://www.akhara.com/nc30/nc30manuals/ ... Manual.pdf" onclick="window.open(this.href);return false;
i went to adjust the A/F screws on my rvf carbs and one of the 4 brass nipples on the screw snapped off. holy shit says i, i'll have to be more careful with the next 3. oops, 3 snapped adjusters and only one fully screws out, so i can take the gamble and run the carbs with these settings or source new A/F screws from honda ( or any one else on here breaking a set of RVF carbs ....)
looking at the above manual i'm having trouble trying to finger out which on is the A/F screw.
can anyone help ?!?!?!
It's not having what you want  but wanting what you've got....Loud ,Proud and Modified ....
						- royster81
Re: need help with RVF400 carb parts
is it part number 4, 16016 kbh 000 ?
It looks like it could also be part #10.
				G-MAN
Good man Royster and you have the right part 16016 kbh 000 . I did the same
						- royster81
				fastdruid
That's what I did.
Actually rather than fix the dogs on 2nd and the worn needles I replaced engine and carbs! 120quid; Bargain!
Druid
Druid
				viper_biker
Not cheap buddy, but at least if you get new ones then you know they are new and not pobbibly buying another duff set of carbs with the same problems.
				fastdruid
Always the problem isn't it, thankfully It was a decent sub 20k engine & carbs and made the world of difference.viper_biker wrote:Not cheap buddy, but at least if you get new ones then you know they are new and not pobbibly buying another duff set of carbs with the same problems.
Druid
				Spike16
call rick o, he has sets of carbs that he breaks for spares, I needed a float bowl and drain screw and new honda was like £20 he did it for £3 I think
