3TJ discs
joshua102
- Bike owned: Gsx-R600K9 3tj NC35
3TJ discs
The front discs on my 3TJ are pretty well worn so I,m looking to get some replacements,anyone got a good pair or can anyone tell me if discs from another yam will fit ? Cheers Josh
Re: 3TJ discs
There are a few other Yam's that fit. You want 298mm dia with a smaller hole for the hub.
TRX TDR 850, FZR600 and Foxeye and the FZS600 Fazer (early)
joshua102
Re: 3TJ discs
Cheers evil ,gives me a few more options . Is that any FZR 600 or only certain models
Cheers Josh
Cheers Josh
Re: 3TJ discs
I think the early genisis type may be different but they'll be old. Personaly I'd look for the Fazer ones as they'll stand a better chance of lower mileage.
Remember it's better to pay and extra £20-30 and get a good rather than a borderline pair
griff488
- Bike owned: ZX10R, SZR660, R6
Re: 3TJ discs
Hi mate
I have a set from a 1988 3EN1 if they're any use to you?
Cheers Griff
Cheers Griff
Re: 3TJ discs
They're not big enough the 3en1 is 285mm dia the 3TJ is 298mm ... they changed in 1989 with the 3en2
- Motorcycle Solutions
Re: 3TJ discs
I HAVE A SET OF 3EN2 SPARE GOING IF YOU WANT THEM......
joshua102
Re: 3TJ discs
Sorry but I'm getting a bit confussed,are discs from a 3en2 the same as 3tj
Re: 3TJ discs
Yes the 3en2 ones i have are 298mm and have used them on my 3tj race bikes.... will re measure and let you know.
joshua102
