RVF front end help?
robefumi08
RVF front end help?
I am currently fitting an RVF front end with ZXR 400 yokes to an NC30.
All ok so far the only problem being is what do i need to fit:
1.a nc30 wheel
2.in the rvf forks which
3.are in the zxr 400 yokes
I have RVF spacers but they don't seem to fit.
Does anyone know the length of the RVF spindle,
and any information to what i might need?
Many thanks regards lee
1.a nc30 wheel
- royster81
Re: RVF front end help?
you need = rick oliver ......
- hannakournikova
i know where there is a set of cnc rvf yokes with a stem for the vfr...bolt on!
robefumi08
everything is there it is just fitting the NC30 front wheel in the RVF forks with the ZXR 400
Yokes?
Spacer sizes etc.
Yokes?
Spacer sizes etc.
russ tyson
Yeah Gavin at jap4 had some a while back ive got a set on me bike they are very nice.If the zxr yokes are the same width as the honda ones then you just need some rvf spacers off Rick O or Honda I didnt know zxr yokes fitted with rvf forks... well you learn something everyday. Russhannakournikova wrote:i know where there is a set of cnc rvf yokes with a stem for the vfr...bolt on!
Edit: you do need the rvf spindle as well its slightly longer.
- hannakournikova
these are different from gavins ones...
robefumi08
Thanks Guys:) I have the RVF Spacers and thats where the questioning came about there
seems to be to much space, about 0.5cm either side of the spacers, and couldn't see tightening
them up would make that gap up.
I have the RVF Spindle. just needed to know spacer sizes
for this type of conversion.
cheers so far
cheers so far
tanuki
so the RVF fors do fit ZXR yokes then?
Hmmmm radial front end.....
robefumi08
Yeah i have ZXR 400 Yokes, with RVF 400 Forks.
Just need the spacer sizes to fit an NC30 Wheel
robefumi08
I have seen a NC30 with a zx636r front end.
Have the picture somewhere will have a look.
