HOW 2 ADJUST PRE LOAD TO CARRY PILLION 88,3EN1
				iancullen7
- Bike owned: fzr400 88 fzr600 92
YES MY BROTHER WANTS TO TRY PILLION ON SHORT RIDES DONT KNOW WHY THAT SEAT DONT LOOK CUMPHY BUT WHAT THE HELL MY FIRST TIME WITH PILLION ON BOARD SO WHAT ADJUSTMENTS CAN BE MADE AND HOW AND WHERE CHEERS ANY HELP WILL BE APRIECIATED   88 3EN1
 88 3EN1
						 88 3EN1
 88 3EN1-
				buzzawak
Re: HOW 2 ADJUST PRE LOAD TO CARRY PILLION 88,3EN1
First off, you need to fix you caps lock key it must be broken dude!
On the top of you shock is a stepped cam, turn it clockwise to increase preload the other way to decrease.
If you don't have the c spanner you can use two screwdrivers one on each side
as above ... but with out the screw drivers
Put some more air in the tyres - a copule of psi in the front and about 4 in the rear.
Take it steady, don't try an be a racer because the bike will feel very different with a pillion ... remember brake early and don't slam them on, be progressive.
				iancullen7
will be doing the things you suggested next time done a dry run with no changes to tyre presure or adustments to the shock only went 4m circut on damp roads with this set up the back end was vvtwitchy i didnt feel safe at all i was glad to get back to my bro's upright he on the other hand said when we goin out again
