Front Brake lever judder
shipley manx
Post by shipley manx »
On My NC35 the brakes give the feeling of being uneven, but the clock gauge says otherwise. Somebody says that the brake lever can give this feeling.Anybody else heard of this. Took the rubber boot of the end of the front master cylinder and cleaned it out, seemed to help a little. Any advice from any body.
cbr400rrn
Bike owned: NC29 CBR600F
Re: Front Brake lever judder
Post by cbr400rrn »
Try the pins in the front calipers, just take them out and have a look if they have any grooves in them and if so new ones arent that much.
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
maybe check the anti rattle spring in each caliper......is the disc warped?,axle bent,check the bolts or maybe even the wheel bearings or a fecked front wheel.......possible causes.
Cammo
Post by Cammo »
I used to get a bit of lever judder when they weren't bled properly, i.e. air at the master cylinder.
