Tyres?
dickyholdsworth
Bike owned: FZR400
Tyres?
Post by dickyholdsworth »
Hello i'm new here i have just purchased an FZR400 RRSP track/race bike having raced sidecars for many years i have now come in from the cold and decided to give two wheels a go, so i need help.
The bike has been raced recently but i'm a bit confused with the tyres. It is fitted with a Pirelli super corsa 110/70 ZX17 on the front which seems fine but is this the best make and size of tyre for racing this bike in the F400 class.
The rear is fitted with a Bridgestone 155/635 R18 it looks to me like a racing slick that has had some cuts added to it?
Again what's the best tyre to use for the F400 class in place of this tyre?
Also while i'm at it what dry tyre pressures would you recommend?
Cheers in advance ;)
Re: Tyres?
Post by Evilchicken0 »
An RR SP ... will have the frame number starting 3TJ ... Probably 3TJ02 ... and should have 17" wheels front and back.
Your's could be a FZR400R SP and have a frame number starting 2TK which would be a 17" front / 18" rear
dickyholdsworth
Bike owned: FZR400
Re: Tyres?
The frame number is: 1WG-036139
I didn't know it should have 17" rear so something is a miss then :(
dickyholdsworth
Bike owned: FZR400
Re: Tyres?
Done some more research and this frame number should mean my bike is a 400RSP?
Is this right and if so is the standard rear wheel on this model 18"?
Re: Tyres?
yes that's right ....
The model is FZR400R SP 1WG and the rear is an 18"
dickyholdsworth
Bike owned: FZR400
Re: Tyres?
OK thanks for that Evilchicken0 so now i know what it is.
Can anybody offer any help on race/track day tyres etc. ;)
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Re: Tyres?
Post by Taggyd »
the dunlop alpha 10s are supposed to be pretty good! the 1wg i have has a 110 rim but runs a 120 tyre which is pretty common as the pirelli doesnt come 110 size, but i have a 17 inch wheel from a 3tj which takes the rear pirelli
Re: Tyres?
I "think" I saw the BT090 Pro come in 18" ... but it's not a slick if that's what your after
dickyholdsworth
Bike owned: FZR400
Re: Tyres?
Thanks evilchicken i will have a look at that, i'm not after a slick as i want to run in the F400 class and that means treaded tyres
Harveyb
Re: Tyres?
Post by Harveyb »
Taggy wrote:the dunlop alpha 10s are supposed to be pretty good! the 1wg i have has a 110 rim but runs a 120 tyre which is pretty common as the pirelli doesnt come 110 size, but i have a 17 inch wheel from a 3tj which takes the rear pirelli
My 2TK is running a 110 front tyre, as was my previous 2tk 7 years ago. I was told that was the correct fitment for a 3 inch rim.
I've just managed to pick up a brand new pair of GPR70's (forerunner to the alpha 10's) off ebay for £75 posted. Bargain of the year.
