NC30 derestriction boxes
- banoffee
How much do used M-Max boxes go for? Can you still get them new?
Rick Oliver lists one - is it the same principle as the M-Max type? I.e. plug and play by the CDI too?
HRC ones look expensive - do they work with a stock road bike? Any benefits over the M-Max type?
Questions questions
Questions questions
- abrmoto
Re: NC30 derestriction boxes
Is there a difference between RVF and VFR max boxes?
Sure I have one some where but cant remember what it came off.
Aly, pretty sure that rvf boxes plug in at the clocks (no big cdi plug) and vfr plug in at the cdi via 6 & 4 pin connectors.abrmoto wrote:Is there a difference between RVF and VFR max boxes?
- abrmoto
Stick,
Cheers, may have a hunt in the aladins cave that is my garage tomorrow and see if can fins them.
- banoffee
Thanks for the replies. I've found that the Rick Oliver resistor is easy to fit and only £6 so have ordered one of those
