Fitting a bluelflame tailpipe!! Help!
ibby4585
Bike owned: SP's
Post by ibby4585 » Sun Aug 02, 2009 10:39 am
Hi.
I have just bought a blue flame oval titanium tailpipe for my NC30. It has the original tailpipe on it but it has been cut already so i can fit my blue flame. Question! i have the inlet pipe and jubliee clips to fit but do i need to apply any sealant on the two joints? i am sure the inlet is right but im unsure it will be an air tight fit with just the clips!! hopefully you can help!!!!
Kris
Biff
Re: Fitting a bluelflame tailpipe!! Help!
Post by Biff » Sun Aug 02, 2009 11:42 am
I would try it without first then run it, if it blows then look at using some sealant..
paul nc 24
Bike owned: 2000 R1
Post by paul nc 24 » Sun Aug 02, 2009 11:59 am
it wont hurt to put a smear of exhaust assembly patse on its only about £4.50 from halfords.
but as biff says try it dry first.
run the bike and place your palm over the exhaust tail pipe the engine should slowly cut out once the revs drop release your hand and try again if your system is leaking your engine will only be slightly affected this is the method most mot stations use to check for leaking exhausts. if it is leaking dont try this method untill the paste has cured (help it go off by running at tick over or you will blow the paste out.)
hope this helps
ibby4585
Bike owned: SP's
Post by ibby4585 » Sun Aug 02, 2009 12:23 pm
excellent thank you!!
rcv4
Bike owned: 2xnc30 nc35 rd200 xt500 dt250
Post by rcv4 » Sun Aug 02, 2009 5:47 pm
i prefare to use silicone to seal slip joints.
mattydrvf
Bike owned: Rvf baby
Post by mattydrvf » Sun Aug 02, 2009 6:25 pm
rcv4 wrote:i prefare to use silicone to seal slip joints.
Don't you find as soon as the silicone gets a little amount of road grease etc on it, it tends to break down quickly and needs replacing.????
