electrical brake light / indicator problem
pugparcels
Post by pugparcels »
ok this may not be anything anyone can help with as this issue is arising from my nc30 fireblade project. i have connected up the tail light electrics today ( led ) - all work fine side light and brake light only when lever is as normal.
i have connected the rear indicators along with the front ( both not led ) and when the indicator is turned on they work and at the correct flash rate but they seem to be causing the tail light to flash as well - only slightly but enough to notice.
just wondered if anyone has any ideas? i will try to look over it properly tomorrow. if my memory serves me the indicators on a standard 30' connected to wires coming off the head lights?
as i now have 600rr lights it does not work that way. so i have presently just have the blue and black connector blocks which has three wires coming into them, however i can only use two to get the indicator to work the third is currently going no where.
if it makes a difference the turn signal on the dash is currently not flashing when the indicators are on, im guessing this maybe becasue of the third wire as well, i am gona have another go in the morning but i just wanted to see if anyone had any thoughts before i have another go......
Cammo
Re: electrical brake light / indicator problem
Post by Cammo »
I have a similar problem on my nc30, when I switch high beams on the brake light illuminates a bit brighter.
I'm not attempting to sort it out because I made this loom from scratch so It'll be a nightmare. I'll just live with it.
dannyboy
Bike owned: HONDA VFR400R NC30
Post by dannyboy »
ABIT OF TOPIC BUT HOW DO I UPLOAD PICS ONTO DISCUSIONS LIKE MEMBER BIKES!?
pugparcels
iv been doing some searches on google and have come across a woman who had the same issue on a punto - turned out to be a bad earth causing the issue. so i am having another go later with this possability top of my list. will keep you informed.
