CREAKING NOISE
Q007
- Bike owned: FZR 400 1wg 1986 FZR 600r 1995
CREAKING NOISE
My bike seems to have developed a creaking noise when the rear suspension is compressed, problem is it's so loud that i can't pinpoint it to cure it. I've sprayed a whole large can of wd40 on just about every joint and pivot point on the frame subframe and suspension to no avail. it still creaks like an old barn door and is soooooo annoying..anyone ever had this before and if so how did you cure it...?
slowly goin insane
Q
slowly goin insane
Q
Re: CREAKING NOISE
The suspension linkage bearing and bushes
Q007
Re: CREAKING NOISE
STRIP AND REPLACE OR WILL A GOOD CLEAN AND REGREASE SUFFICE...?
- Motorcycle Solutions
Re: CREAKING NOISE
They might be seized so strip and clean to evaluate the problem.
plodder
Re: CREAKING NOISE
Bearings may have corroded and pitted the tube (then you're fkd)
Re: CREAKING NOISE
I think you can still get the linkage from Yamaha - Phil's 3en2 did this (or something like it)
buzzawak
Re: CREAKING NOISE
Hi Lajracing,lajracing wrote:They might be seized so strip and clean to evaluate the problem.
On a completely different topic, Can you supply inner and outer bushes for 38mm front forks?
Re: CREAKING NOISE
Um .... the picture in your other thread showed what I thought to be a 3en2 .... that's a 41mm fork, and 298mm dia discs .... unless you've got an 3en1 or fzr 600 3HE front end.buzzawak wrote:Hi Lajracing,lajracing wrote:They might be seized so strip and clean to evaluate the problem.
buzzawak
Re: CREAKING NOISE
Remember we concluded that its a 1wg with 3en2 bits bolted on.Evilchicken0 wrote: Um .... the picture in your other thread showed what I thought to be a 3en2 .... that's a 41mm fork, and 298mm dia discs .... unless you've got an 3en1 or fzr 600 3HE front end.
The forks are 38mm (I measured them with my trusty digital micrometer).
Re: CREAKING NOISE
Time for an upgrade then
>>> post the reply in the original thread or start a new one
