Sprocket Bolt
howl
Sprocket Bolt
Post by howl »
Hi Just wondering if the front sprocket bolt has a an anti clockwise thread before I put a big breaker bar on it ,as it is bleeding tight . Cheers
Cammo
Re: Sprocket Bolt
Post by Cammo »
It's normal (RH) thread.
mick.mh2racing
Re: Sprocket Bolt
Post by mick.mh2racing »
Yeah it is a normal thread but think on it'll work tighter over the life of the chain. Lock the wheel and get a big f*** off bar and it'll eventually give. WD40 and rock it a bit and will give up the ghost in the end.
How hard can it be?
thefatman
Re: Sprocket Bolt
Post by thefatman »
It took 8ft of scaffold pole to get mine off, and two people holding down the back of the bike so they can be fairly tight.
viper_biker
Re: Sprocket Bolt
Post by viper_biker »
Also, when you re-fit the nut make sure it's to the correct torque setting. I had my bolt work itself loose recently and it eventually broke the sprocket cover housing with the strees it put it under,
howl
Re: Sprocket Bolt
Post by howl »
Hi Chaps
Thanks for that ,I kind of knew that it was a std thread but as it is going to take a fair bit of undoing, I just thought I'd ask. :D
