Advantages / Disadvantages fittine HRC CDI to stock rvf 400
fielder09
Forum
Pro's and Con's for fitting a HRC CDI to my stock RVF 400 !!
Will i see big changes in power and what other work would need done ?.
Malcolm
Malcolm
tom wood
Re: Advantages / Disadvantages fittine HRC CDI to stock rvf 400
it didnt make a great deal of difference to my bike, i tried it back to back with the std one on a dyno. It does seem to pick up a bit cleaner and the flatspot at around 6K seems a bit better. they are a lot of money now. Rick oliver sells programmable ones with the hrc map on which are cheaper. and then you can adjust it if you want to
fielder09
Thanks tom
any idea where i can get in touch with rick oliver ?
Bike going on dyno hopefully this time home and i will be able to see how it is fairing from there.
Rick is a member on here.
Have a search for ignitech and you'll see the in's and out's
Funny you should ask this...fielder09 wrote: Pro's and Con's for fitting a HRC CDI to my stock RVF 400 !!
I recently changed my cdi from an HRC one to a standard one and it suits me better. My bike has hrc carbs, full exhaust, etc.
The hrc unit gave a little more top end, the std one has better midrange, my bike pulled noticeably better out of corners at the revs I was using. Incidentally the bloke I bought it off sold it cheap to me as back to back dyno runs proved the same for him.
Personally I'm happier with a standard unit, if you're a gun of a rider you'd want the hrc unit though.
A programmable unit would be a better option for me (not allowed to race with them in Oz though).
fielder09
Cheer's for the help jave seen some stuff on ebay that may do the trick.
Malcolm
Malcolm
Hopefully you're not referring to the chinese garbage cdi's?fielder09 wrote:Cheer's for the help jave seen some stuff on ebay that may do the trick.
