Fitting HRC rear brake pipe
- chrisja2
- Bike owned: nc29 trackbike
Bought one of the kits, arrived through the post. Unfortunately the envelope had come partially open. Now i have the green tube, a bung and one small jubilee clip. Have fitted the tube ok but the jubilee clip appears to be too small. Am i missing a part or is it the wrong one? Apart from that it appears straight forward. Cheers in advance.
Chris.
Chris.
chris
Re: Fitting HRC rear brake pipe
From memory (it has been a long time since i fitted one) the tight fitting jubelee clip goes on the bottom to hold the tube onto the master cylinder and there should be like a springy clip thing that sits above the barb on the bung and prevents it from popping out.
tanuki
+1 although I never bother with the spring clip thing only the jubileechris wrote:From memory (it has been a long time since i fitted one) the tight fitting jubelee clip goes on the bottom to hold the tube onto the master cylinder and there should be like a springy clip thing that sits above the barb on the bung and prevents it from popping out.
- chrisja2
Right my jubilee clip is to darn small so ive fitted one of my own, works a treat now with the microswitch fitted too !tanuki wrote:+1 although I never bother with the spring clip thing only the jubileechris wrote:From memory (it has been a long time since i fitted one) the tight fitting jubelee clip goes on the bottom to hold the tube onto the master cylinder and there should be like a springy clip thing that sits above the barb on the bung and prevents it from popping out.
:D
tanuki
mate we need to hook upfor a spin soon..
- chrisja2
Why are you back on the road billy? What about wednesday evening MFN?tanuki wrote:mate we need to hook upfor a spin soon..
tanuki
all done and dusted mate I am working until 7 on Weds and Thurschrisja2 wrote:Why are you back on the road billy? What about wednesday evening MFN?tanuki wrote:mate we need to hook upfor a spin soon..
- chrisja2
Ok let us know Billy, will meet ya up there and have a drool over the 35.tanuki wrote:all done and dusted mate I am working until 7 on Weds and Thurschrisja2 wrote:Why are you back on the road billy? What about wednesday evening MFN?tanuki wrote:mate we need to hook upfor a spin soon..spose I could get a dog burger up there.
tanuki
- chrisja2
Looks good to me, what time would you be setting off over there?
