carb and mirror gsxr 400 gk73a
johnwilkinson71
I need a good set of working carbs for a gsxr 400 gk73a, can anyone help me. I also need a right hand mirror for the same bike. many thanks john
blagger
Re: carb and mirror gsxr 400 gk73a
i have got an old set going about here somewhere from when i used to have my gk73a
johnwilkinson71
Hi, do they work and how much do you want for them.
cheers
john
cheers
john
blagger
Hi
I hunted my old carbs out, they cam from a working bike so they should be ready to bolt straight on, i did notice that part of one of the plastic caps lung is damage but the seal doesn't leak and is still securely bolted down.
here are a few pics of the carbs
£25 + £10 RMRD (Uk Mainland)
Richie
Richie
tractor664
hi did you manage to sell your carb,s as im looking for a set also or just a single carb body (my mixture screw is siezed solid )
blagger
Sorry mate they are now sold
tractor664
ok thanx for quick reply... maybe john (if thats who bought them )would be interested in selling his old set as i only need 1 carb body ....
M1KE
Ive got a set of 33mm bandit carbs im willing to sell, but i think your gsxr will have 32mm's on it. So you'd have to put the whole bank on not just swap over the one body. They had new o rings a couple of years back, only selling cause i bought another set which had a jet kit in them. £60 delivered to your door.
tractor664
will keep in mind mike ..mine are 32mm so may have to change inlet rubbers too poss even airbox side aswell .. i,ll keep looking for 32 mm slingshot carbs unless anyone can say for definate that the rubbers will stretch to 33,s and fit on air box side .......thanx anyway
M1KE
If you measure the outsides of your carbs on both sides inlet and airbox then we can see if they are any bigger in my memory they are the same size just the inside has been bored out more.
