150/60 R18 in a 3EN2
				Kenny_Dave
- Bike owned: FZR400 3EN2, FZS600 mk1, RF600
Re: 150/60 R18 in a 3EN2
Cool, ta. Glad to know I'm not alone too
				sevenfourate
- Bike owned: FZR400-R
What was the conclusion on the 150/60-18 fitting a 3EN2 ? Wanting to order some rubber and wanting to get some wider rubber on the rear if i can.
What are the options on a standard 140 width 18" rear (With front to match) if not ????
******By my rough reckoning,with the current standard 140 in,i have 15-20mm gap between edge of tyre and inside of swingarm,and approx 30mm from tyre to swingarm brace (Tyre is half worn).......
				Kenny_Dave
Well, the width in theory should be 10mm wider so would go. The concern would be the height, as the 150/60 should in theory be 6mm taller than a 140/60, although looking at the Avon 150/70 and 140/70 that doesn't hold.sevenfourate wrote:What was the conclusion on the 150/60-18 fitting a 3EN2 ? Wanting to order some rubber and wanting to get some wider rubber on the rear if i can.
The clearance to the swingarm brace depends on the chain tensioner position, so you could hit problems if you get a new chain on. Although, the standard tyre should give about 25mm so it sounds ok.
The only 140/60 R18 I could see was a BT-92, and had the shop looking too and they came back with the same conclusion.
				Kenny_Dave
The jubilee clips seem to have done the job on the exhaust, thanks for the advice!!!Kenny_Dave wrote:Cool, ta. Glad to know I'm not alone too
				sevenfourate
Kenny_Dave wrote:Well, the width in theory should be 10mm wider so would go. The concern would be the height, as the 150/60 should in theory be 6mm taller than a 140/60, although looking at the Avon 150/70 and 140/70 that doesn't hold.sevenfourate wrote:What was the conclusion on the 150/60-18 fitting a 3EN2 ? Wanting to order some rubber and wanting to get some wider rubber on the rear if i can.
I been told they will definately fit by a couple of guys in the US running 150/60-18's in the US.
Thanks for your help.
