HRC carb upgrade
Re: HRC carb upgrade
Looks nice how does it run with that r6 filter setup? you had it on the dyno?
I must say i do like your little video guides
- Bike owned: XT600Z,'10 TE250 ,XS650 chop
That was last March,pre season.
Made a shade over 60hp with really good fueling.
Mid range was perfect.
The motor was well tired at that stage, completly gutless at the end of the season.
Hence the (hopefully) stronger motor now installed.
On a different note,I recently replaced a fuel pump on an Africa Twin with a Facet solid state unit.
Going to use the same on my new setup.
It's smaller,lighter and more reliable.
Anyone used this pump?
So which year R6 is the filter from, i might try one of them for my open carb setup.
It looks like its bolted through the original airbox mounts?
Never used one of them pumps but it only be better than an old zxr pump, will look trick too.
It's not a BMC now that I surf the web.
It's off a carbed R6 00-02.
The stock item has a sponge type washable element with a mesh cage beneath.
The filter bolts straight on,just drill 2 holes in its lip.
Between a NC30 HRC spec and a NC35 one, which one would you run and why?
