More electrical testing....
- thunderace
- Bike owned: R6, YZF600R
Re: More electrical testing....
That's not large enough for stator wiring, it works out at 14AWG. Ideally you want 10AWG (5.26mm sq) or larger.Neosophist wrote:2mm square should be fine for most things.
http://www.ebay.co.uk/itm/5M-2mm-12V-AU ... 3a7ab315d5
Bikemonkey, domestic cable is a no no. Use proper automotive cable
- bikemonkey
I consider myself told off then
So I need some 5.26mm sq for the stator and reg/rec plug wiring then?
@CMSMJ1, yeah I did use it as stator wiring.....
- thunderace
Either 14AWG or 6mm sq. that's the nearest metric equivalent
Try and get the extra flexible silicone stuff and some fibreglass braided sleeve as well to protect it from any heat.
- bikemonkey
This stuff good then? (forgive all my questions, electrics are not my strong point as you all may have worked out
http://www.ebay.co.uk/itm/GANTRY-LIGHT- ... 3378c3ce40
http://www.ebay.co.uk/itm/360506025995
- thunderace
bikemonkey wrote:This stuff good then? (forgive all my questions, electrics are not my strong point as you all may have worked out)
Yep and Yep
- bikemonkey
Problem now solved by my new proper wiring, bike is charging its self at idle like it used to
Hopefully I shall read things properly next time and not create long threads out of being a numpty with a previously shit soldering iron. Thanks to Steve (thunderace) for a recommendation on a good soldering iron
- jim157
What soldering iron did you get? I've got a cheap one from Maplin but it's a bit shit.
AUTOEXEC.TWAT
- bikemonkey
I got a antex xs25 with the silicon flexible wire, it's so much better than my old draper cheapy from the local autostore
