HRC carb upgrade
gonzothegreat
Re: HRC carb upgrade
Post by gonzothegreat »
CMSMJ1, do you have any pictures of the mesh filter please?
Alreet Gonzo
I use the base for the usual filter and I have 3 sheets of HRC foam in there. I'll have a squizz through my pics and see what's what.
It is a basic chop and hack up job. Not sure it does my motor much good..but the bike works lovely with it
gonzothegreat
Thats an NC30 setup - the 35 "should" use the HRC airbox and filter.
I reckon that mesh setup looks wicked though..
gonzothegreat
thanks again for the info, by "should use" does that mean I could have a similar NC30 setup (ie in the picture above)?
CMSMJ1 wrote:Thats an NC30 setup - the 35 "should" use the HRC airbox and filter.
Yes, the '30 was setup to run open carbs where the '35 setup included an airbox in the kit list.
A few people on here have modded their carbs to '30 HRC spec. I just sold some..
Cammo has some, Indiaguy I think too...and Martin as well..and Royster if I have my brains working.
gonzothegreat
Can you run the NC35 HRC spec ones in an open configuration?
gonzothegreat wrote:Can you run the NC35 HRC spec ones in an open configuration?
No, its designed to work with a airbox,
gonzothegreat
thanks, that's what I wanted to know :up:
Indiana Jones
Bike owned: XT600Z,'10 TE250 ,XS650 chop
Post by Indiana Jones »
http://www.youtube.com/watch?v=ZjAPE_qtoo4
A little bit in on the vid you can see my R6 filter, just about a perfect fit. I think it's a BMC.
