carb seals would they cause running problems
Re: carb seals would they cause running problems
Yeah see how it goes with those parts fitted, they can make a big difference.
Pilot screw setting only affects the performance just off-idle (e.g. pulling away from stationary). The standard pilot screw setting is 2 turns out, best to use 2.25 if you have a non-standard exhaust or pipe.
