Engine Oil leaking
Re: Engine Oil leaking
he used silicon bathroom sealant then?niteblade wrote:i did not open my engine to replace my output shaft seal. my mechanic did some slight alterations to my seal and guaranteed me it wouldnt leak in a long long long time (i'll keep you guys updated on it)
niteblade
- Bike owned: NSR150SP, RVF400
as you guys all know, there is some sort of lip holding the seal in place. the gasket was slightly altered so it could fit in, he then used some sort of high grade heat resistant gasket sealant around it... i opened up the engine cover to check on it. seems like its holding up pretty well but only time will tell...
apparently alot of nc35's in singapore have done this quick fix for 80SGD as it costs almost 500 to 1000 SGD just to open up the engine here... so i guess i'll take this gamble first...
Delboy
Depends how long you intend keep the bike and how deep ya pockets are
revkid78
hey bro i have emailed u. but just want to make sure you get the post. Where did you do the output shaft leak?
