the battery is not charging (update)
brido
Re: the battery is not charging
Post by brido »
Thanks Neosophist for going through my findings and you made it sound so simple, I have a new one ordered so thanks again.... :grin:
nakes999
Post by nakes999 »
I fitted a CBR400 NC29 regulator/rectifier that I have on loan until I get a replacement... all seems good so far. So Thanks for the advice and info :peace:
Just one more question... my original Regulator/Rectifier was clearly opened up before as it's been silconed closed... It also has two additional wires coming out. The one goes to ground the other goes to the rear flicker unit... Any idea what that's all about?
All seems ok with the NC29 Regulator/Rectifier... also, is there any reason I shouldn't use the NC29 rectifier? I wouldn't wanna destroy it because it's just a loan unit...
All honda units are crap, even the new ones. Hence all the vfr750/800 problems.
For £15-20 you can get a 2nd hand GSXR reg thats 1000x better. Ask Cam / Dataracer.. :-)
Old batteries dont' take charge well and the r/r units dont' dissepate the extra heat too good and tend to die.
No idea on your existing reg/rec.. maybe its an aftermarket model? Pics would help..
nakes999
Post by nakes999 »
I'm in South Africa though and bike shops here will sell a GSXR Reg/Rec for more than 15 - 20 GBP equivalent... Should I be looking for any GSXR Reg/Rec?
I think my busted Reg/Rec is the std unit that was opened and hacked, then closed with silicone...
The Green wire was bolted to ground and the blue wire went into the rear flicker unit...
Pic:
brido
Post by brido »
Hi everyone just to let you all know that I received my new reg/rec and fitted it and that did the trick my battery is now being charged, so again thanks to everyone who lent a hand with advice :grin: can't wait now for the snow to melt and get back out on the road.....
Re: the battery is not charging (update)
That is good to hear.
On a related note...as I have had my bike in bits I decided to test my reg rec...and it is failing. only 13.5V at 5k and no more....
Bugger :Soap: :violin: :tits:
CMSMJ1 wrote:That is good to hear.
Time to bid on this and put this badboy on then ;)
http://cgi.ebay.co.uk/YAMAHA-R6-REGULAT ... 4a9eb7f441" onclick="window.open(this.href);return false;
nakes999
Post by nakes999 »
Anyone know if the Fazer 600 reg/rec is as good as the R6 one?
Good find mate...I am now bidding on it...so you lot, keep your snouts out! :rock:
nakes999 wrote:Anyone know if the Fazer 600 reg/rec is as good as the R6 one?
No idea, are they the same part? If not, for the price you can get them i'd just get an R6 one.
Mark:
http://vtr1000f.wickidnet.com/" onclick="window.open(this.href);return false;
Theres all the info you'll need, including pictures and wiring diagrams :-)
