new to rvf400's and wants more low end
Cammo
Re: new to rvf400's and wants more low end
Post by Cammo »
It will be running lean at idle.
You can probably get better idle and off-idle performance by setting them to where they need to be.
dr_46
Post by dr_46 »
ok awesome...i am doing it now does it have to be precise?.....and while i have the carbs off is there anything else i can/should do?
dr_46 wrote:ok awesome...i am doing it now does it have to be precise?.....and while i have the carbs off is there anything else i can/should do?
Yes it has to be precise :P otherwise it'd be 1 and whatever you feel like out :grin:
It's not hard once you get it in your head
There you go.. as you can see, if your screwdriver is Vertical (|) you need to turn it half a circle so its' still (|) but upside down.. then one more of the 8th notches :-)
Good luck! You'll have it running in no time
dr_46
Post by dr_46 »
CMSMJ1 wrote:
Midrange is also boosted by longer pipework. Get a proper can on it too.
tyga maggot comming soon..
i love working on my bike hahahahaha so what else can be done....
the bike runs smother but still dnt seem right how should the bike act n feel after the mods and carb clean....perhaps i am just used to how it was
A Maggot doesn't really count - it is a short and noisy can. We are talking 400mm+ for a proper sized long can.
A shorter exhaust length, in general, is more suited to higher revs and top power.
dr_46
Post by dr_46 »
well my carbon fiber can now is probably shorter than the maggot due to my accident...and the maggot sounds good and looks awesome.... :mrgreen: is it a massive differance in power...what other mods can i do to this beautiful 2 wheel machine....
+1 on the maggot can, it's not far from being a straight through can and if your after more midrange your be wasting your time with this. But if you really must have one then im sure someone could advise you on a decent setup for running one although i doubt it'll give you much in the way of midrange.
Well....do you want more low end as you stated or do you want to piss your neighbours off and get annoyed with 110db exhaust all the time?
dr_46
Post by dr_46 »
id like more low end/midrange power....pissing off my neighbours has already be done...the maggot is a slip on so ill keep the can i have now and when i want a quiet little cruise ill slip it on...i want the most out of my bike on the road till eventually i get my bearings and jump to the track so low n mid range would be best....ill invest in a propper tyga can but keep the maggot for the big rides i go on just so u can hear me over the r1s cbr1000's n gsxr1000's... :grin: is tere anything else i can do to improve my bike power wise??? :?: will get a 14 front and 43 rear sproket...i have heard good things about hrc jet kits and airbox's??....but let me guess they are high range mods right?
dr_46 wrote:id like more low end/midrange power....pissing off my neighbours has already be done...the maggot is a slip on so ill keep the can i have now and when i want a quiet little cruise ill slip it on...i want the most out of my bike on the road till eventually i get my bearings and jump to the track so low n mid range would be best....ill invest in a propper tyga can but keep the maggot for the big rides i go on just so u can hear me over the r1s cbr1000's n gsxr1000's... :grin: is tere anything else i can do to improve my bike power wise??? :?: will get a 14 front and 43 rear sproket...i have heard good things about hrc jet kits and airbox's??....but let me guess they are high range mods right?
This may help, from another thread
RonniB wrote:35 engine and carbs, fit an ignitech cdi and hrc jet kit from Rick, get a TPS from cbr 400, tyga twin stack, some sort of under carb air tray and run the carbs semi-open (just a filter on the airbox baseplate). This is a high torque road setup, which is going to be just as smooth and fuss free as the original setup once jetting and setup is done.
And when you come to jetting, sort out your main jet first, then the pilot screw/jet and finally the needle taper/height. And use Ricks method of carb sync before you do anything with jets..
