Non starter
Re: Non starter
Album now public; I altered the setting on the main page and thought it applied to all sub albums
The dia. is all in Japanese and B/W; its like trying to read this; %>[{]}=%$#, does my head in
Cracking idea on inverse pic. (top tip of the year)
If OP prints off a few copies and has some coloured pens, he could easy work out what's what; the little icons are self explanatory.
Re: Non starter
Nice signature
- Bike owned: FZR400 3EN2
Re: Non starter
Have been in garage this morning.
Disconnecting the larger of the two plugs at the TCI unit results in no Exup cycling or fuel pump prime.
Re: Non starter
Evilchicken0 wrote:Nice signature
Aristotle (circa 322BC) "One swallow does not a summer make".
Amended by someone on here
Re: Non starter
Yes, I was originally talking about a Yamaha yellow spring on an SP shock. Somebody described it as an Ohlins because Yamaha owned them .... it lead to "Ohlins-a-like"
Re: Non starter
Just tried a third relay from a running bike with no luck. Next move is to try a digital ignition box.
Fingers crossed
We'll get there eventually. Cheers for all the advice
Fingers crossed
Re: Non starter
did you bridge the solenoid terminals ?
Re: Non starter
Yes bridged and the starter motor spins. Just got an ignition box so I can try it tonight. Also got a Haynes manual for the 600/750/1000 with details of how to test the relay with a multimeter and battery. pretty sure the wires are same colour
