Page 3 of 15
Re: NC30 running on 3.
Posted: Tue Mar 18, 2014 5:20 pm
by NGneer
arsey30 wrote:The float needle valve has a spring loaded pin that sits on the float level adjuster.
:worthy: I bow to superior knowledge - but if one is doing something different to the other three, and it is on the suspect carb, then logic would say it needs sorting. I am sure someone will be along shortly with some top advice, or possibly some spare bits to swap out the bits in question.
Posted: Tue Mar 18, 2014 6:12 pm
by bikemonkey
I have a scrap set of carbs.... :grin:
Including four working float needle valves, drop me a PM if you're interested.
Posted: Tue Mar 18, 2014 6:26 pm
by mitchyboy01
bikemonkey wrote:I have a scrap set of carbs.... :grin:
Hi thanks for the offer!!
Will do if it comes to that. I've checked all the float heights and all are fine. After further investigation I think the valve is still springy but just not enough to push the float out when upside down. I would be surprised if it actually affected the carbs operation.
Does Rick Oliver often answer his phone as I've tried a few times today and this evening?
Also, Is it worth me getting a new set of HT leads from RO? Mine look like the originals. Secondary coil resistance was 24k ohms I think which was with the multimeter in the plug caps. Is this proof that they are functioning correctly?
Thanks.
Posted: Tue Mar 18, 2014 6:27 pm
by bikemonkey
Rick's a busy man, best to e-mail him and ask him to ring you I find.
Posted: Tue Mar 18, 2014 7:10 pm
by NGneer
bikemonkey wrote:Rick's a busy man, best to e-mail him and ask him to ring you I find.
:plus:
Posted: Wed Mar 19, 2014 1:09 am
by mitchyboy01
:plus:
Got hold of Rick in the end and have ordered my gaskets, fuel hose and a new set of HT leads.
Posted: Wed Mar 19, 2014 1:58 pm
by mitchyboy01
Just took all the plugs out. Spot the odd one out! Plug gap = 0.1mm.
Strangely this wasn't from the cylinder that was giving me grief.
Looks like the washer hasn't been compressed either like on all the others.
Looks to have melted. Thought it was carbon build up at first.
Plugs have done under 500 miles.
Posted: Wed Mar 19, 2014 2:35 pm
by richyrd5
looks like u need to check/set ur mixture screws chap.could be running lean although doesnt look like tbf.
Posted: Wed Mar 19, 2014 5:35 pm
by mitchyboy01
richyrd5 wrote:looks like u need to check/set ur mixture screws chap.could be running lean although doesnt look like tbf.
Yeah carbs have been off this week and serviced. I don't think it has run lean. The plugs were a light brown colour. The one which has melted was actually darker than the rest. Probably melted due to having zero plug gap DOH!!
Posted: Wed Mar 19, 2014 6:14 pm
by richyrd5
yeh.but i doubt it was put in like that.(at least i hope not!)must be a reason its got like that.
