uk nc30 frame vin plate
hunter
Re: uk nc30 frame vin plate
Post by hunter »
If it was mine i would cut a hole on the inside of the frame behind the dent,
Place the frame on a steel block and tap the dent out, dress it down then weld the hole back up.
philfingers
Bike owned: NC30 Type 7
Post by philfingers »
or, just weld the hole up from the outside, no point in drilling a hole and knocking it out when you're filling with weld. I would fix the hole, you can do that with the motor in, just remove the CDI
NC30 type 7, mods: Art can, Ohlins shock & RO fork kit
superfour1300
Bike owned: nc30 ttr600 cb1300fw cb1300sa7
Post by superfour1300 »
philfingers wrote:or, just weld the hole up from the outside, no point in drilling a hole and knocking it out when you're filling with weld. I would fix the hole, you can do that with the motor in, just remove the CDI
I wouldn't want to see the repair..
philfingers
i don't think you would if it was done properly
